Power Steering Getting Harsh After Long Ride
2007 FORD EDGE
150,000 MILES • 3.5L • 6 CYL • AWD • AUTOMATIC
KOKO.121
  • 34 POSTS
i have a 2007 ford edge in my garage .. the problem is that after driving the car for a long distance the steering becomes harsh as if it's not hydraulic .. so is there any similar problem happend with you and what can be the solution thank you
Jan 15, 2014 at 6:09 AM
HMAC300
  • 48,601 POSTS
try replacing your belt and tensioner first as the tensioner may lose tension causing this. make sure fluid is full as well.
Jan 15, 2014 at 7:39 AM
KOKO.121
  • 34 POSTS
the power steering pump belt doesn't have a tensioner
Nov 20, 2014 at 4:30 AM
HMAC300
  • 48,601 POSTS
if no tensioner then it's adjustable try adjusting it then
Nov 20, 2014 at 6:19 AM
