Steering wheel very difficult to turn at a stop and slow speeds
2009 BMW 328XI
115,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
STRATOMAN
  • 4 POSTS
On highway seems to handle fine. Power steering reservoir is full but does not appear to be circulating when running. Serpentine belt replaced last December and appears tight.
At stop, steering wheel turns an inch or two, then I feel resistance and have to force it to turn further. Help!
Dec 20, 2019 at 8:27 PM
If you have noticed that the fluid isn't circulating as the belt is tight, chances are the pump will need replaced. However, I have a question. If you rev the engine slightly, do the symptoms change?
Dec 20, 2019 at 8:35 PM
STRATOMAN
  • 4 POSTS
I did not check if symptoms change with engine reviving . Will have to check in the morning.
Dec 20, 2019 at 8:37 PM
STRATOMAN
  • 4 POSTS
Pump replace, is that a do it yourself repair or does it require professional?
Dec 20, 2019 at 8:38 PM
I have tried to send all directions but have been unsuccessful. Here are the basics for replacement. If you need torque specs, let me know.
pic 1
Release hose clamp (1) and detach intake pipe (2) from vane pump.
Installation note:
Markings on intake pipe and vane pump connection must match up.
pic 2
Release bolt (1) and remove bracket with refrigerant line.
Unfasten screws (2).
Installation note:
Replace aluminium screws.
Observe screwing sequence!
pic 3
Release banjo bolt (1) and disconnect pressure line.
Installation note:
Replace all sealing rings (D).
Make sure pressure line is laid without tension and with sufficient spacing to adjoining components.
_________________________________________________
Let me know if this helps.
Dec 21, 2019 at 7:14 PM
STRATOMAN
  • 4 POSTS
Thanks, after reading this, I think this is over my head . But appreciate the detailed reply. Thanks
Dec 21, 2019 at 7:25 PM
Not a problem. If you change your mind, let me know.
Dec 21, 2019 at 10:09 PM
