Need to transfer EVO solenoid from the old pump to the new pump are there special tools a special way to remove it? I can't find any information.
Mar 7, 2020 at 6:41 PM
STEVE W.
CERTIFIED EXPERT
The EVO solenoid is part of the pump. It isn't a transferable part because it is fitted internally to match the pump. As such there are no instructions on it's transfer. A new or rebuilt pump should have had it already installed and only needed the reservoir connected up. There was a pump that didn't have an EVO for another model. Is it possible you have the wrong pump?
Mar 7, 2020 at 6:50 PM
CERTIFIED EXPERT
There is no official process to do this because the EVO solenoid should come on the new pump. Did your pump not have one on it?
Take a look at the picture below. This is how the pump should come with variable assist. I don't show an option for non EVO so where did you get this pump? Was it a used pump? Can you get a picture of it or the part number and manufacturer and I can see if we got the right pump?
