Power steering mis leaking from the pressure hose at the steering gear?
2010 FORD FLEX
90,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JBELCHER91
MEMBER
1 POST
FOLLOW
I replaced the rack and pinion a year ago. Now my car is leaking from the pressure hose at the steering gear. what could be causing this?
Nov 25, 2024 at 8:42 AM
CERTIFIED EXPERT
The power steering lines have seals which must have gone bad, but I would check the fitting to make sure it is tight. Here is what I am talking about. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
