Power steering not working
2018 FORD TRANSIT
172,000 MILES • V6 • 2WD • AUTOMATIC
NOLEN PETERSON
I tried a bottle of Lucas oil stop leak and refilled the power steering fluid, but it did nothing. There is no sign of leak.
Aug 31, 2020 at 7:34 AM
Good morning,
The stop leak was a bad decision. That stuff just swells the seals to try to get it to work again. The problem is it swells them so much that they break and then you have damage to the pump and the steering gear itself.
https://www.2carpros.com/articles/power-steering-problems
I would flush the system first to get rid of that stuff and see if it is any better.
https://www.2carpros.com/articles/power-steering-fluid-flush
If not then the pump and gear should be replaced.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
I attached pictures of the pump and the rack assembly for you.
Aug 31, 2020 at 7:57 AM
NOLEN PETERSON
Thank you for the help and the links.
The problem existed before I put the stop leak in there, I'm just wondering how flushing it could improve.
Aug 31, 2020 at 8:06 AM
It most likely will not but the last thing you want to do is let that stuff get into the new parts and contaminate them and have them fail in a short period of time.
Aug 31, 2020 at 8:09 AM
NOLEN PETERSON
Oh, I gotcha.
Thanks
Aug 31, 2020 at 8:17 AM
You are welcome.
Always glad to help.
