Hi Jenny and thanks for using 2CarPros.com. If you are purchasing a rebuilt unit, the company may be having issues. As far as install, I have attached the directions specific to your vehicle. Also, there are two different engines available for you vehicle so I will attach pictures of both. Read through the directions and make sure you are not missing a step. If you are not, I would try a different brand pump.
The first set of directions are for the 2.0L Turbo, as well as the first three pictures.
2006 Saab 9-3 (9440) L4-2.0L Turbo (2.0 T)
Vehicle » Steering and Suspension » Steering » Power Steering Pump » Service and Repair
SERVICE AND REPAIR
Power steering pump, B207 petrol engine
Important: Scrupulous cleanliness must always be observed during all work with hydraulic components.
To remove
Detach the return hose, wipe up any fluid spill with a cloth and plug the reservoir pipe using 82 92 955 Plugs, spare part kit. Suspend the hose so that fluid does not run out.
Remove the electrical connection of the pressure sensor.
Remove the delivery pipe from the pump. Wipe up any oil spill with a cloth.
Remove the pump. Some engine oil may run out.
Empty the fluid from the pump.
To fit
Fit the pump using a new gasket.
Tightening torque 22 Nm (16 ft. lbs.)
Connect the return hose.
Connect the delivery line using new gaskets.
Tightening torque 32 Nm (24 ft. lbs.)
Connect the electrical connection of the pressure sensor.
Fill with fluid and bleed the power steering system. Check for leaks.
THESE ARE FOR THE 2.8L as well as the remaining pictures.
CONVERSION CALCULATOR
2006 Saab 9-3 (9440) V6-2.8L Turbo
Vehicle » Steering and Suspension » Steering » Power Steering Pump » Service and Repair » Power Steering Pump
POWER STEERING PUMP
Power steering pump, B284
To remove
Remove Drive belt, auxiliary.
Remove pipe, mass air flow sensor and hose from the turbo.
Remove the upper engine cover
Remove the turbo delivery pipe.
Raise the car.
Remove the turbo delivery pipe and the bolt securing the turbo delivery pipe to the AC compressor.
Lower the car to the floor.
Remove the turbo delivery pipe bolts on the front of the engine.
Remove the battery cover and radiator pipe.
Remove the upper radiator mounting from the radiator member.
Press forward the radiator and remove the turbo delivery pipe.
Clamp the supply hose with 30 07 739 Hose pinch-off pliers.
Remove the delivery hose from the power steering pump, use 32 025 061 Special wrench.
Remove the supply hose from the power steering pump.
Remove the power steering pump, press forward the radiator and lift out the pump.
To fit
Fit the power steering pump.
Fit the supply hose and remove the pliers.
Fit the delivery hose.
Tightening torque 30 Nm (22 ft. lbs.)
Press forward the radiator and fit the turbo delivery pipe. (Do not fasten yet.)
Raise the car.
Fit the turbo delivery pipe to the AC compressor and connect the hose.
Tighten the delivery pipe screws.
Fit the upper turbo delivery pipe.
Fit the radiator mountings.
Fit the pipe, mass air flow sensor and hose to the turbo.
Fit the upper engine cover.
Fit Drive belt, auxiliary.
Fit the radiator pipe and battery cover.
Fill with oil as specified and bleed the power steering system. Check for any leaks.
I hope this helps. Let me know if you have other questions.
May 27, 2018 at 8:34 PM
