Replaced the power steering fluid and it still will not steer?
2006 KIA SEDONA
200,000 MILES
SABRINAWILSON
I bought a car and they let me test drive it. I drove it maybe 30 miles over a 3-week period no steering problems no grinding not hard at all I when to take it to have an o2 sensor replaced and a block from my house the power steering goes from fine to nothing. I instantly popped the hood and that's when I saw the sop I bought it from let me test drive and go home with no fluid in it except washer fluid, but I replaced the fluid, and it still won't steer.
Apr 17, 2024 at 2:08 PM
I need you to check a few things. First, start the engine and allow it to run for a few minutes. Turn the engine off and open the fluid reservoir to see if there are air bubbles in the fluid.
If there are, safely lift the front wheels from the ground. Make sure the fluid is full. Then, turn the steering wheel all the way to each side several times. Recheck the fluid level and refill if needed. Then restart the engine and see if it made a difference.
Also, here is a link you may find helpful:
https://www.2carpros.com/articles/power-steering-problems
Let me know what you find and if there are any noises associated with the issue.
joe
Apr 17, 2024 at 6:19 PM
