Power steering
1992 TOYOTA PREVIA
236,000 MILES • 4 CYL • FWD • AUTOMATIC
ASH020998
  • 4 POSTS
So their is a rubber tube that has got a crack in it and is leaking my power steering fluid, the fluid is still full so it must not be leaking much but now whenever I'm turning it is impossible to turn the wheel with my foot on the break, as long as I am gassing it, it turns fine. I was wondering the estimated cost for repairing this, labor included. Only looking for an estimate doesn't have to be exact.
Aug 21, 2016 at 10:39 PM
SATURNTECH9
  • 30,869 POSTS
So what are we replacing? the hose that is leaking? I do not which hose it is I cannot see it. You are my eyes. is the power steering system full?
Aug 21, 2016 at 10:42 PM
ASH020998
  • 4 POSTS
Yes, the hose that is leaking need replacing. I was asking around and was told it is called the bellow I believe. And yes power steering fluid is full.
Aug 21, 2016 at 10:46 PM
SATURNTECH9
  • 30,869 POSTS
If the fluid is full then replacing the leaking hose is not going to restore your power steering. Also I have never heard of a power steering hose called the bellow .There is a pressure side one and a return hose.
Aug 21, 2016 at 10:50 PM
ASH020998
  • 4 POSTS
It is probably the return hose. what else could cause my steering to do this?
Aug 21, 2016 at 11:06 PM
SATURNTECH9
  • 30,869 POSTS
A bad power steering pump or bad rack and pinon?
Aug 21, 2016 at 11:08 PM
ASH020998
  • 4 POSTS
And how much estimated would it be to replace either of those, labor included?
Aug 22, 2016 at 3:42 AM
SATURNTECH9
  • 30,869 POSTS
What is your zip code so I can get you an estimate for your Area?
Aug 22, 2016 at 5:53 AM
