Can you get a recording of this noise because I suspect this could be a faulty actuator if this was not doing this prior to the replacement?
Basically, what can happen is the actuator contacts inside of it are faulty and the clicking you are hearing is the actuator moving but not staying engaged in that position, so it clicks rapidly.
We may have to remove the panel and get this to operate in order to be sure this is what it is.
https://www.2carpros.com/articles/door-panel-removal
We should be able to hear or feel what is clicking so let me know if you have questions on this.
However, this could also be a connection issue as well if you changed the harness, so we need to check these as well.
So, let's see if you can get a video of this noise and we will be able to determine what this may be because most things have distinctive noises.
Thanks
Apr 9, 2022 at 9:16 AM
