Power seats don't work and neither does either of the automatic sliding doors.
1998 PONTIAC MONTANA
139,000 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
BONNIEBLUE1
MEMBER
FOLLOW
Neither of the power seats do not work and neither do either of the sliding doors.
Feb 28, 2015 at 6:34 AM
HMAC300
CERTIFIED EXPERT
for doors scan for codes as it may be a body module problem and then check if circuit breaker in fuse box if sending power to switch it may be switch or check to see if switch sends power to motor. a pro will have to scan for codes auto parts can't do it.
Feb 28, 2015 at 6:52 AM
BONNIEBLUE1
MEMBER
where is body module you mention. And, which switch are you referring too?
Feb 28, 2015 at 10:47 AM
BONNIEBLUE1
MEMBER
I heard this was a common problem and that power seats and sliding doors both are affected.
Feb 28, 2015 at 10:48 AM
HMAC300
CERTIFIED EXPERT
the switch is the one that operates the seats. body module is item 7 in pic. If you replace it a pro has to program it to your vehicle as they are vin specific
Image (Click to enlarge)
Feb 28, 2015 at 10:50 AM
BONNIEBLUE1
MEMBER
is the module in the fuse panel on the right side of the dash?
Feb 28, 2015 at 10:59 AM
HMAC300
CERTIFIED EXPERT
rh side of dash but a pro has to use his scanner to match to your vehicle if you have ideas of replacing it your self.
Feb 28, 2015 at 1:18 PM
BONNIEBLUE1
MEMBER
I guess you mean it is under the dash, and not in the fuse panel.
What about the power seats? I will check for power on the plug under the seats. Both don't work.
Mar 1, 2015 at 6:30 AM
HMAC300
CERTIFIED EXPERT
yes it's under the dash for the bcm and really don't kow why you wan to find it. as for switches see if power is going to them if not it can be the circuit breaker in fues panel is bad or a short in wiring.
Mar 1, 2015 at 8:21 AM
BONNIEBLUE1
MEMBER
You mention that a pro would have to change the bcm. That was one reason for contacting you. I know they charge about 85 an hour at the dealerships.
Mar 1, 2015 at 4:29 PM
HMAC300
CERTIFIED EXPERT
any garage with a pro model scanner can do this not only dealers.
Mar 2, 2015 at 7:38 AM
BONNIEBLUE1
MEMBER
Ok thanks.
I Have no power to seat switches, but have power leaving fuse for the seats.
When I push the switch for the automatic door, I hear a click just behind the rh sliding door.
Mar 2, 2015 at 5:00 PM
HMAC300
CERTIFIED EXPERT
there is a circuit breaker for seats check that it's in fuse box I cannot get into manual so I can't give anymore answers at the moment try tomorrow if you could. my manual is online. if you are h earing a click in one door then the motor might be shot but I ned the manual to trace a few things first.
