Power seat switch not working properly
2002 CHEVROLET MONTE CARLO
66,300 MILES
COLLEEN MAHAR-WILLIAMS
The power seat switch stopped working properly. It will not go forward or backwards. It will go what I would say up and down. I am trying to get a video on how to change it but I am not finding any. I hope that you will be able to help me.
Jan 27, 2018 at 4:26 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
No video but here are the instructions.
Power seat switch > Removal and installation:
Disconnect negative battery cable. Remove front seat cushion outer trim panel. Release power seat switch retaining tabs. Pull switch away from outer trim panel, and disconnect electrical connector. Remove power seat switch. To install, reverse removal procedure. Ensure harness connections are tight and power seat switch is firmly seated in outer trim panel.
Jan 27, 2018 at 5:05 PM
How do you take off the two nobs that are next to the switch?
Jan 27, 2018 at 5:20 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Try this video, https://www.youtube.com/watch?v=ub_2XsDi6xI
Never mind, he is only adjusting the seat.
Jan 27, 2018 at 7:10 PM
