Power to the driver's seat depends on two things. First, fuse J8 in the under-hood fuse box (40 amp), provides power to a 25-amp circuit breaker. That sends power to the seat switch.
Both the fuse and circuit breaker are located in the same power box under the hood. If you look below, I attached a couple pictures to help.
Check the fuse first. If it is good, then I recommend going to the switch on the seat. There will be an orange wire with a red tracer. Check it for power.
Let me know what you find.
See pics below.
Sep 18, 2024 at 5:59 PM
