Power outlet socket cover replacement
2012 TOYOTA HIGHLANDER
90,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
KEVINTEICHEN
I am looking to see how to replace the power socket located on the center console. Toyota part number is 85535-06020. Looking to know how to replace the socket cover only which is the part I provided to you. Thanks in advance.
May 1, 2019 at 11:51 AM
Welcome to 2carpros.com
You will need to remove the center console finish to remove and replace the cover assembly. I have attached the directions for removal first. The second set of directions refer to the cover and power outlet. All attached pictures correlate with these directions.
__________________________
28. REMOVE UPPER CONSOLE PANEL SUB-ASSEMBLY
(a)Disengage the 4 claws and 4 clips.
pic 1
(b)Disconnect the connector and remove the upper console panel sub-assembly.
REMOVAL
OTHER SYSTEM: CIGARETTE LIGHTER: REMOVAL
1. REMOVE CENTER INSTRUMENT CLUSTER FINISH PANEL ASSEMBLY (w/o Smart Key System) See: Dashboard / Instrument Panel > Removal and Replacement > Removal
2. REMOVE CENTER INSTRUMENT CLUSTER FINISH PANEL ASSEMBLY (w/ Smart Key System) See: Dashboard / Instrument Panel > Removal and Replacement > Removal
3. REMOVE POWER POINT SOCKET ASSEMBLY
(a)Disengage the claw and remove the power point socket assembly.
pic 2
4. REMOVE POWER OUTLET SOCKET COVER
(a)Disengage the 2 claws and remove the power outlet socket cover.
pic 3
Installation
OTHER SYSTEM: CIGARETTE LIGHTER: INSTALLATION
1. INSTALL POWER OUTLET SOCKET COVER
(a)Engage the 2 claws and install the power outlet socket cover.
pic 4
2. INSTALL POWER POINT SOCKET ASSEMBLY
(a)Engage the claw and install the power point socket assembly.
pic 5
3. INSTALL CENTER INSTRUMENT CLUSTER FINISH PANEL ASSEMBLY (w/o Smart Key System) See: Dashboard / Instrument Panel > Removal and Replacement > Installation
4. INSTALL CENTER INSTRUMENT CLUSTER FINISH PANEL ASSEMBLY (w/ Smart Key System) See: Dashboard / Instrument Panel > Removal and Replacement > Installation
Let me know if this helps.
May 1, 2019 at 7:29 PM
