I replaced the water pump on my 1988 Lincoln Town car and after an ORDEAL of broken water pump studs and broken easy-outs, etc. the car sat about a week and a half with the battery disconnected. Finally got Humpty-Dumpty back together again, hooked the battery back up, went around to fire it up and nothing. The courtesy lights had been on, and the dash lights all lit up as they are supposed to before starting, but as soon as I turned the key, all the lights went out and stayed out. That was last night. I had to get to class, so I took our Jeep. When I came back, still nothing. It was dark and cold, so I waited till after work today to look at it again. Still no power. Then, I pulled the cover off the fuse box and checked a few of the fuses, and I suddenly realized the interior lights were back on. I went to start it again, and the same thing happened. All the lights went out.
Is this the circuit breaker? What can I do?
The battery shows 12v with the multi-meter. But no lights come on when I open the door.
Feb 19, 2015 at 5:52 PM
