When the check engine light comes on the engine idles fine, the A/C compressor stops working, and there is a loss of power when trying to accelerate. When the check engine light is off everything is fine. The check engine light is intermittent and has only come on after the truck is warm. The truck does not run hot. Codes are not stored and unable to be read with quality readers at a reputable repair shop. Please let me know if you had this issue and found a solution. Thanks
Mar 22, 2021 at 9:57 AM
