I just replaced my timing belt, water pump, spark plug wires, but did not change spark plugs because I just replaced it awhile back. After I ran engine I got the check engine light. I took everything back off and redid the TDC. This time check engine light is out but the tachometer is reading 1000 rpm. I then adjusted the TPS to 650 rpm everything runs okay, but it seems like when I accelerated, it felt like I am losing power and it sounded a cylinder is not firing.
Nov 6, 2017 at 9:28 AM
