The past week I had some stalling happening while on idle (engine was warm and temperature was -2). I replaced the fuel filter and that seemed to do the job for 2 days. On the third day it was losing power, especially when uphill and decreasing gears didn't seem to help a lot. Since then, I replaced MAF and MAP sensor, one at a time when I did the MAF it drove as should for about 30 miles, I turned the van off for an hour and then it would start to lose power again. Nothing seemed to change when I replaced the MAP after that happened. I get no error codes neither from my OBDII scanner or forscan (at least anything that might seem related). Any idea what could cause it?
Dec 5, 2023 at 9:37 AM
