Power Locks don't work when key is out of ignition, and radio doesn't work at all. ALSO RPM needle is still fluctuating after throttle bore actuator.
After getting the throttle bore actuator cleaned the RPM needle still continues to fluctuate causing the lights to dim and come pack on. I took it back to where I bought it, the "mechanic" then plugged in his computer reader to my car, I tried to open the door to get inside and then he said I messed up his machine by trying to do so. So now my radio doesn't work at all, and the power locks don't work unless the car is on with the key inside. I'm so lost and stuck and now my car is in worse condition than when I brought it to him.
I checked all of the fuses both under the hood and below the steering wheel and none of the fuses are blown or burnt. The "mechanic" said he just needed to get his computer fixed so he can fix my computer. But my question is how does that get done ? I tried to go to autozone but their tiny computer didn't even come on when he connected it.
Dec 11, 2013 at 8:41 AM
