Power locks
2006 DODGE DURANGO
125,000 MILES • 5.7L • V8 • AUTOMATIC
VAL MONTAGUE
I can only lock and unlock the doors manually. The power locks on the arm rest and the FOB do not work. Windows work fine. I also do not have access to the back because the lift door will not unlock. Any ideas? The fuse looks fine on it.
May 3, 2018 at 7:46 PM
It sounds like you have an accessory delay relay that is not working. Here is a guide to help you:
Here is the door lock wiring diagram so you can see how the system works and the location of the relay.
Check out the diagrams (below).
May 6, 2018 at 12:23 PM
