Hello, the lift gate has its own module for controlling the gates functions. It's a pretty complicated system. The lift gate module communicates with the BCM for some functions. There may be Diagnostic trouble codes stored in the liftgate module or BCM. Most of the cheaper scan tools won't communicate with individual modules. There is a list of tests that can be done, but most of them require a special scan tool. I'm going to provide as much information as I can on this systems faults. Plus the connector locations. There are a lot of possibilities why the system may not be operating correctly. There are some tests listed below but as I said they require a scan tool that can communicate with at least the BCM. A full system scan should be done to see if there's any codes in any modules. Local auto parts stores will do a scan on the vehicle, that might turn up a code and give you some direction in diagnosing this issue. You can at least get to the connections for the module on page 3 below. You can check the connectors in the rear left of the body. See if there are any corroded connectors, also check any body ground connections back there too. If the key fob does flash the lights, it's at least sending a signal to the module. *Edit I've added the wiring diagram for the liftgate system as well. After some further research, it seems this is a problem with a lot of these vehicles. Some have been liftgate motor failure, the power liftgate drive unit has an optical sensor that can fail. But start with checking the wiring in the rear of the vehicle.
Mar 16, 2021 at 10:07 AM
