Car started fine, but the alternator was not charging it, battery drained again
2001 TOYOTA ECHO
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
JESSE JOESTAR
Hi, I'll try and give a series of events as accurate as possible.
One day the car wouldn't start. I figured I left the lights on or some other mistake.
I bought a new battery and installed it.
Car started fine, but the alternator wasn't charging it, battery died again.
Bought a new alternator and installed it.
Boosted the vehicle, it started.
Car shut off after about 5 minutes of running (presuming it was still running off the battery).
Checked the alternator fuse with a multimeter because I'm out of ideas, fuse seemed fine.
May 28, 2022 at 10:26 AM
It sounds like the alternator is not working, to be sure this guide will should you how to check it using a voltmeter. Also, if the alternator is bad, I have included the instructions in the diagrams below to show you how to change it out.
May 28, 2022 at 7:55 PM
