No power coming from the ignition coil
2003 DAEWOO MATIZ
15 MILES • 0.8L • 3 CYL • 2WD
ARO RAJ
Have a crank shaft position sensor in this vehicle?
And how to check ignition wiring?
May 4, 2018 at 10:35 PM
STEVE W.
  • 15,113 POSTS
Well after hunting around a bit it looks like it does use one.
GM/Daewoo part# 96325868.
No variant of this car was sold in the US, so I do not have a reliable wiring diagram to go by but most crank three wire crank sensors work in similar ways. Reference voltage on one terminal, ground on another and the third is the actual signal.
May 6, 2018 at 2:43 PM
