post cat oxygen sensor
2000 MAZDA PROTEGE
170,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
ZEMORZEMOR
  • 486 POSTS
I have intermittent check engine light p0420. i checked the voltage of the post cat oxygen sensor it was fluctuating between 0.420 to 0.435
Feb 6, 2016 at 11:13 AM
HMAC300
  • 48,601 POSTS
420 is a bad catalytic converter, either there is an air leak prior to converter, O2 sensor bad or converter. most of time it's a converter especially if higher mileage.
Feb 6, 2016 at 1:16 PM
ZEMORZEMOR
  • 486 POSTS
what should be the reading than
thank you
Feb 6, 2016 at 2:48 PM
Here is an article on to replace the cat
https://www.2carpros.com/articles/catalytic-converter-replacement
Feb 9, 2016 at 6:28 PM
ZEMORZEMOR
  • 486 POSTS
so is the cat bad?
Feb 10, 2016 at 7:10 AM
If there are no upstream vacuum leaks, most likely the cat is bad, sorry to but in Harry :-)
Feb 10, 2016 at 2:42 PM
ZEMORZEMOR
  • 486 POSTS
do you mean by upstream the exhaust side or intake side
Feb 10, 2016 at 6:28 PM
Exhaust side, if it was intake side you would have a lean code, not a cat inefficacy code. Here is more information on that
https://www.2carpros.com/topics/trouble-codes/p-codes-powertrain/p0400-p0499/p0420
Feb 11, 2016 at 11:09 AM
ZEMORZEMOR
  • 486 POSTS
Thamk you for your help.
is there any chance in the future somebody else answer my questions beside HMAC300. because his answers they are 95% is: take your car to a mechanic:
thank you
Feb 11, 2016 at 8:32 PM
ZEMORZEMOR
  • 486 POSTS
when i idle 80% the after cat o2 sensor is lean around 0.1v . when i accelerate (shifting gears) the after cat o2 sensor is a almost a mirror of the pre cat o2.
when i cruise the after cat of sensor is rich around 0.8v. check engine was on , now is off and all monitor are ready including catalytic converter
Dec 20, 2016 at 2:50 PM (Merged)
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
ZEMORZEMOR
  • 486 POSTS
I checked the fuel pressure is good.
Today the the code p0420 came back.the freeze frame data IS
lTFT 5.5
STFT -2.3
Speed 40
Rpm 2380
That info is good, its telling you you have a cat converter that is weak, this is a common problem
here is more information on how to replace it
VESHKI
hoy to reaplace front the oxygen sensor of 2000 mazda protage 4cylinder 1.8L with picture.
WRENCHTECH
  • 20,761 POSTS
There aren't any instructions to post. You unscrew the old one and screw the new one in.
SHERISHERI
  • 4 POSTS
Diagnostic tool brings up code P1170. I have put in two new 02 sensors, the top one and the bottom one, then erased the code from the car, drive about 60 miles and the engine light comes back on giving me the same code, P1170. Any ideas? Thanks in advance
MHPAUTOS
  • 31,937 POSTS
Possible causes
- Faulty HO2S-11 Sensor
- HO2S-11 Sensor harness is open or shorted
- HO2S-11 Sensor circuit poor electrical connection
Scanners are a smart diagnostic tool but can be very dumb at the same time, yes it is saying that there is a problem at the O2 sensor, but you have to look a little deeper into the problem this code is for an open circuit or poor connection and not necessarily a faulty sensor, so you need to check all connections for loose or corroded connections and do a pin out from the sensor back to the ECU to look for open circuit or high resistance, start here.
SHERISHERI
  • 4 POSTS
thank you, I'll try that
MHPAUTOS
  • 31,937 POSTS
OK, good luck with this , these can be tricky to work out, re post if you have any furtjer questions.
LADYBUD
Engine Performance problem
2001 Mazda Protege 4 cyl Front Wheel Drive Automatic 12500 miles
I just wanted to ask that if bad gas or air pushing into your tank can it cause or o2oxygen sensor connected towards the muffler to malfuction.
Cause when i went to put gas in and didnt feel prssure of the gas going into my tank..but theyt charged me for the gas and since then check engine like came on and need to repair the above and just want to see if there was dirt or air from the gas pump pushed into my tank could this cause my problem stated above.
thanks
LADYBUD
[quote:f50ee6181b="ladybud"]Engine Performance problem
thanks[/quote:f50ee6181b]
