I had an issue of the car stalling and sometimes shutting off on me while driving
And also sometimes the Needle of the engine temperature is bouncing up and down giving unreal values.
I have an issue with three sensor, Ambient temperature sensor, Coolant temperature Sensor, crankshaft sensor.
I connected the star diagnostics tool and i had the stored faults read
1-crankshaft position sensor has a malfunction signal is not present.
2-Engine coolant temperature sensor has a sporadic value.
3-Ambient temperature sensor has a short to ground.
I replaced the sensors but the issue isn’t fixed. It seems like the sensors has an intermittent issue where they disconnect and connect again.
I am afraid it is the ground circuit of the ECM.
And i needed some advice on how to track this issue.
Note: I am an electromechanical engineer freshly graduated.
Jul 30, 2019 at 5:20 AM
