Two months ago, I pulled onto the street and within a minute the RPMs shot up and I could barely go 20 MPH. Since then, I had several Instances of the same thing, but they were briefer. If I kill the engine and restart the issue disappears and the car drives as if nothing happened.
I have no check engine light. The battery and alternator test fine. There is no stalling or sputtering. I have no leaks anywhere and no trouble shifting gears. The mechanic who looked at it said he felt it was most likely a transmission problem. The car pulled no Transmisson codes.
It did pull an airbag code as well as the history codes.
C1109 voltage low
C1622 EMS invalid vehicle speed.
B1112 ignition voltage low.
I'm stumped and don't know what to do next.
C1109 voltage low
Oct 20, 2023 at 6:30 AM
