So, I bought this car about 2 months ago because it was a one owner with a lengthy maintenance record. I started noticing right off that while driving at a steady speed mostly (but even at other speeds but not as common) between 40-55 MPH there is a hiccup that jumps 2 or 300 RPMs for a second then drops back down. also, I don't know if it's related, but I've noticed depending on how I'm accelerating there is a chugging sputter sometimes in that same are when shifting around the 40-50 MPH area. overall, it seems as it drives fine and at higher speeds it happens much less often drives mostly smoothly at higher speeds. I changed out the spark plugs and that didn't make a difference. My buddy said possibly the coils but there's no engine light on so without replacing all four which I don't have the money to do unless for sure that'll correct the issue, I don't want to go that route but from what I'm told without the engine light if it is a misfire, I'm the coils it wouldn't show on a scan. Any suggestions are helpful. thanks
Apr 26, 2022 at 7:45 AM
