possible fuel pressure issue
1999 PONTIAC MONTANA
82,000 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
PAMBER
I got two OBDII codes p0452 and p0453 both are FTP sensor low and high, I checked this because when I went to start my van after getting gas, it started..,ran sputtery..., and died, now it turns over but if it starts(barely) it just dies...the check engine light goes on and the oil light...OBDII code says its the FTP dendor, just wanna verify im on the right track
Apr 19, 2017 at 1:18 PM
CARADIODOC
  • 34,306 POSTS
P0452 - Evaporative Emission Control System Pressure Sensor Low Input
P0453 - Evaporative Emission Control System Pressure Sensor High Input
The common mistake is the fault codes do not say to replace a part or that one is bad. They never do.
While it is possible the sensor is defective, setting two opposing codes is much more likely to be the result of a wiring or connector terminal problem. Also, problems in the vapor recovery system won't stop an engine from starting and running. For that, a better suspect is a failed fuel pump. A pressure gauge would show the lack of fuel pressure, but you must also check for spark. More crank / no-start problems are caused by a loss of injector pulses AND spark, than are caused by a loss of either one.
Apr 19, 2017 at 2:36 PM
