Possible engine damage, there is a hissing noise coming from the hood, could it be a vacuum leak?
2003 ACURA TL
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAUSHAL JOSH PAI
My car is making a hissing noise coming from the hood. I drove today and had to hard brake and now having some big issues that are causing performance issues. Wanted to know can a vacuum leak cause these?
Aug 13, 2024 at 5:25 PM
A vacuum leak can cause the engine to run differently. If it is a large enough leak, the engine may not start.
What is the vehicle doing? Is it possible for you to record the sound and upload it for me to hear?
Also, here is a link that explains how to locate/fix an engine vacuum leak. Check to see if you can find a possible issue.
Additionally, here is a link that explains common symptoms of a vacuum leak:
https://www.2carpros.com/articles/automotive-engine-vacuum-leak-symptoms
Aug 13, 2024 at 9:13 PM
