Jiffy Lube drained engine oil(6qts) and for some reason put 2 qts of auto Trans fluid in motor. Drove 106 miles then motor started knocking bad. They flushed engine, replaced filter & added 6 qts of correct oil. Slight intermittent knock. When I get to shop knocking stops. Up till this always serviced at dealer. Jiffy Lube gave me a 2 yr/ 24k mile warranty on motor. What damage is done and is this warranty ok? Never had any issue w/ truck. Expecting long life but concerned life if motor is greatly reduced.
Jan 22, 2016 at 7:04 PM
