This is the first summer with vehicle and found cold air will not blow with the air conditioner on. My first instinct was to buy refrigerant and fill it up (never did actually put any in). I hooked up the pressure gauge pressure gauge supplied with the can and it read up to about 100 psi with about 80 F ambient temp. Even with the air conditioner on and the fans turned up the compressor clutch would not engage. I read online about bypassing relay to force clutch to engage, but no luck and not even positive if it was done right. Any other theories I could test or is it looking like a seized up compressor? Note: I did not have gauge to test high side psi and no easy access to compressor as its mounted low. Thanks.
May 29, 2016 at 9:29 PM
