need a diagram for position of hydraulic lifters on a flex engine 5.3L.
Apr 28, 2020 at 7:18 AM
CERTIFIED EXPERT
By flex engine are you referring to the Active Fuel Management engine? If that is the case, cylinder 1,4,6,7 are the AFM cylinders. It is also called Displacement on Demand system. I attached the info about the system for your review. Let me know if you need more info about this. Thanks
Apr 28, 2020 at 9:40 AM
SHIPP
MEMBER
yes! Thank you!!
Apr 28, 2020 at 10:22 AM
CERTIFIED EXPERT
Awesome. Thanks for using 2CarPros. Please come back when you need more help on something else. Thanks
