Rattle noise - R-Rear above wheel
PORSCHE
FOORE68
I have 99 Boxter which is making a lot of rattle noise when I hit a bump on the road right around or above the right rear wheel. I've check the rear trunk board under the pad, the engine cover if loose and the top if any screws are loose, but they are all pretty tight. It is bothering me a lot. Left side is perfectly fine. Anyone has the same problem? Please share. Thanks
Jul 3, 2007 at 10:12 AM
2CARPRO JACK
  • 11,533 POSTS
might be a good idea to get under it and gently rap on the exhaust and the such with your hand or a soft hammer (so as not to damage anything) and see if the rattle can be pin pointed
Jul 4, 2007 at 7:49 AM
