cooling fan does NOT stop
PORSCHE
MLONDON
1986 Porche 944 with 106,000 miles. I recently had the battery replaced. Then the next time I went to drive it the battery was dead again. I was told the reason the battery died was not the alternator, but was because the cooling fan relay was faulty and the cooling fan would not stop. I replaced the fan relay, but noticed the cooling fan still does not stop. I take out the relay and the fan stops. I put the relay in and the fan starts regardless if the car is hot or cold. What could be causing the cooling fan to not turn off? And what do I need to replace to make it work? I have no problems with a dead battery as long as I remove the relay while the car is parked for extended periods of time.
Feb 28, 2006 at 12:43 PM
2CARPRO JACK
  • 11,533 POSTS
cooling fan switch
Feb 28, 2006 at 5:46 PM
MLONDON
Thanks for the tip. The mechanic also confirmed the cooling fan switch was faulty. Had it replaced. Car was great for about 4 days. Went out this AM and the battery was dead. Jumped it okay. Car drove great. Got to work and noticed the cooling fan didn't go off after 30 minutes. I pulled the relay out. Any suggestions as to whatthe problem is now?
thanks
Mar 8, 2006 at 11:40 AM
Check the cooling fan relay.
Sep 12, 2006 at 6:43 PM
