944 exhaust smell
1994 PORSCHE
KARMAN
  • 6 POSTS
I have an 84 porsche 944 Manual, and i am getting a bad exhaust smell in the car, the exhaust system has been replaced 6 months ago, what should i be checking? please help......
Aug 27, 2007 at 5:39 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
944's have a real problem with the rear hatch seal, if the seal is in poor condition or the hatch is not locking down fully, you will get exhaust fumes being drawn into the cabin while you drive. The best way to check the seal is to play the garden hose around the seal, you will not need a lot of pressure and check for any seapage past the seal, if water is getting in, the exhaust will as well. If it looks like it's leaking have the seal checked for servicability and also have the hatch lock adj so that it is a good tight seal.
mark (mhpautos)
Aug 27, 2007 at 6:19 AM
KARMAN
  • 6 POSTS
Thank you for the hint, i did what you said and yes water was getting in, i re adjusted the hatch and fixed the problem, great to know that there are some real auto brains out there.
Aug 27, 2007 at 5:31 PM
FABRICGATOR
Porshe 944 has a hood seal just in front of the fresh cabin air box. You can see it (if it is installed) It runs across the chassis just forward of the windshield beneath the hood. It is forward of the battery on the RH side and forward of the fuse box on the left. When this seal is defective, engine (exhaust) smell in the cabin is typical. These seals are still readily available.
May 19, 2009 at 9:13 AM
