How to change valve cover gasket [tork bolts to what pounds of pressure] and adjust timing belt tentioner.
May 9, 2008 at 5:55 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
Thank you for the donation.
I will need the model and engine to be able to help.. On all Porsche engines there is a number of special tools required to work on the timing belt, there is a special belt tension gauge required to set this correctly, do you have access to one of these tension gauges?
Mark (mhpautos)
May 10, 2008 at 2:02 AM
DAVID JORGE
MEMBER
Hi Mark , thanks for your quick reply. I have a 1990 944 s2 cabrio 4 cylinder engine. I don't have the tools yet.
