1987 Other Porsche Models Will crank but not start
1987 PORSCHE
165,000 MILES • 4 CYL • 2WD • MANUAL
BAD BOB
I have a 1987 Porsche 944 non-turbo that cranks but will not fire to the plugs.
I have 12.56 volts at the coil wire on the distributor end, but no spark. Is there a crank sensor, bad distributor or rotor button? I do not have much money and need to get running as cheaply as possible. This car was running when it got parked, now 3 months later won't start.
Can you help?
Dec 11, 2008 at 4:03 PM
THIS IS MIKE
  • 686 POSTS
Here is our page that helps determine which part is failing and some easy tests.
http://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Dec 16, 2008 at 1:28 PM
