1984 Porsche 944 START UP
1984 PORSCHE 944
89,000 MILES • 4 CYL • 2WD • MANUAL
FGSOCALA
Car started and ran perfect. Sat for 5 months and will not start. Battery is good. Plugs look good. HELP
Should I spray starter fluid in #1 cyl
Nov 12, 2009 at 4:01 PM
Before we get started, I have to say, "Great Car!" Okay, now that I said it, we can move on. lol Have you checked to see if you are getting spark and fuel to the engine? Also, if you want to try starting fluid, it would go into the throttle body, not the #1 cylender. If you try the starting fluid and it starts for a few seconds, then we'll know you are getting spark and fuel is the problem. Regardless, here is the how to for checking fuel pressure and spark. I need you to check it so I know which way to direct you. https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm Let me know what you find. Joe PS: One of my favorites!
https://www.2carpros.com/forum/automotive_pictures/249084_944_1.jpg
Nov 12, 2009 at 9:01 PM
