1991 Porsche 911 Noise in moter/transmission
1991 PORSCHE 911
450,000 MILES • 6 CYL • AWD • MANUAL
MIKEBLANKENBAKER
There is a loud clunk when starting or when turning the engine off. I have heard it on both sides of the motor. It's been suggested that it maybe that the fly wheel is loose. I am just guessing that it may be related to the all wheel drive..transfer case connections.. Just a guess Any idea???
Aug 3, 2010 at 11:09 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be getting the drive shaft checked first.
mark (mhpautos)
Aug 4, 2010 at 2:32 AM
CWPORSCHE
  • EXPERT
  • 58 POSTS
If its a manual transmission then what you likely have is a worn whats called a dual mass flywheel. This flywheel contains a heavy fluid that prevents engine oscillations from transmitting thru the trans.Over time the oil escapes out causing the internal components to hit their end stops,thereby creating the knocking noise.An experienced tech knows how to check for wear.Replacing the flywheel will fix the noise.
Aug 5, 2010 at 11:22 AM
