My truck became hard to start. When there was rain/moisture no cranking. By end of day if humidity dropped it would crank. When it did, the muffler exploded. I had muffler installed. Replaced all plugs, wires, dist and cap/rotor button, all 3 oxygen sensors. The engine code reader says PO300 "random misfire". The next phase of testing revealed a bad EGR valve. I replaced it. Reset ECM per specs. Wait a day to clear mind as well. Cranks but still the "popcorn" or "shellfire" sound from tailpipe. I've made sure there are no leaks around 2nd new muffler, exhaust manifold gaskets,etc. The cat was deleted long before any of this started. Drove 15,000 miles post catalytic converter removal without probs. Have added Seafoam to gas tank. Checked all vacuum lines, installed new air filter, cleaned MAF sensor. Regardless of my actions, still a PO300. Please advise. Thanks
May 15, 2021 at 6:18 PM
