i get a popping sound when turning sometimes. My quick inspection i found 2 lower ball joints damaged so I replaced them.
i disconnected the knuckle from the upper control arm and everything else attached to it. got it off the vehicle then i used a ball joint press and pushed the damaged ball joint out. placed a new one in. filled it up with grease.
installed everything back with proper specs and did my test drive... popping sound still happening so jacked up the vehicle and looked at my sway bar links.
the driver side sway bar link is perfectly straight but the passenger side sway bar link is slanted. i suspect this is an issue? what do you think?
Nov 2, 2022 at 1:20 AM
