Two things to look for. Most likely the chemical damaged the delicate sensing element. That can affect its readings. There is a wide range of signal voltages that can be developed by a mass air flow sensor. That voltage has to go outside that acceptable range to be detected as a problem and a fault code to set, but the engine computer will accept any reading that is within the acceptable range, and use it for fuel metering calculations, even if those readings are wrong.
The second issue has to do with the fresh air tube. Check that there are no loose hose clamps or other leaks between the MAF sensor and the throttle body. If any air sneaks in that does not go through the sensor, it will not get included in the fuel calculations.
Feb 28, 2018 at 6:22 PM
