My SUV listed above has had a problem for two years now with barely luke warm heat in the winter. This is occurring at the front, middle, and rear heat vents. I replaced the blend door two years ago (which was broken) but I still barely get any heat. According to the temperature gauge, my engine temperature is running consistently, but the heater hoses are hardly warm to the touch. The engine was replaced with a slightly newer one last summer so I do not think it is a water pump issue (but maybe I have had two worn out pumps?). I have read some blogs which say that there is a heater control valve, but other blogs say they no longer exist. If there is a heater control valve, where is it located?
Dec 12, 2016 at 2:42 PM
