Oil filter location
2010 PONTIAC VIBE
20,000 MILES • 4 CYL • 2WD • AUTOMATIC
CIURLINO
Were is the oil filter located and also the drain plug for the oil. I need to change the oil.
Oct 17, 2010 at 12:12 PM
SQM
  • 6,383 POSTS
The oil filter is located on the lower left side of the engine. This vehicle has a canister style oil filter. You will have to use a oil filter strap to remove the filter cover.
The drain plug is located at the bottom of the oil pan.
This engine uses 4.4 quarts of engine oil.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Thank you.
Sep 3, 2021 at 2:43 PM
