2009 Pontiac Vibe 2010 Oil Type & Quanity
2009 PONTIAC VIBE
2,647 MILES • 4 CYL • FWD • AUTOMATIC
AFWON94
Confused: 2.4L eng oil filler caps states use 5-20W or 0-20W. Manual states use 5-30W. Manual also states fill with 4.5 Qts w/filter change, when filled with 4.3125 Qts, dip stick indicates an overfilled condition by approx. .5 Qt. Indication after running engine for 3 min. Called Pontiac, they stated use what is in manual, dealer called they said use 5-20W. Called Toyota (engine is a toyota 2.4L VVTI, they state
Jul 23, 2009 at 9:30 AM
JNOVACK
  • 723 POSTS
try using 4 quarts then run engine for 3 min then let sit for about 5 min then check level add if needed and use what type that is indecated on the cap 5-20 would be ok to use use 5-30 if you live in high temp area such as 90 degrees
Jul 23, 2009 at 10:14 AM
