Strange Noise
PONTIAC TRANSPORT
SGUERECA
I have a 1997 Transport that had an engine rebuilt, original miles on engine were 80,000. My engine had gone out so now that I have a rebuilt one it's making a strange noise as if it were about to die out.
It feels as if it is not getting enough gas when it's idle. When I accelerate it does not make that noise and it runs fine. We have tried replacing the Mass Air Flow sensor since that's what the scanner had picked up but it did not help.
Do you have any ideas (everything from spark plugs, wires, water pump, belts, tensioners were replaced)
Thank you
Oct 14, 2007 at 8:56 AM
MERLIN2021
  • 17,250 POSTS
Check for air leaks in the air induction plenum. And vacuum leaks...get a can of spay gumout, spray the vacuum hoses and the intake manifold, if the idle changes, you have found the leak...
Oct 14, 2007 at 8:59 AM
