1990 Pontiac Transport SE 62,000 Miles
The raditor fan doesn't come on when the engine heats up or when the MAX button is pushed on the A/C.
If you ground the diagnostic terminal with a paper clip it will come on.
If you cross the red wire and black/pink wire on the relay with the fuse unplugged it will come on.
I replaced the relay, the temp sensor, the temp switch (one with the pig tail made on it), and themostat.
The Haynes book suggest the ECM after I went through its steps. What do you suggest?
Thanks
sheeptender
Thanks
sheeptender
Dec 3, 2006 at 2:48 PM
