Like I said,The car is a 1991 Pont. Transport 3.1 . The car stalled and check engine lite does not come on.When noid light is connected to the injector connector ,there is no pulse(lite). Also with fuel pump(no pulse).Distributor has spark.will ignite with carb spray.
Why is the computer not responding when I hook up scanner.When I checked computer with LED safe Tester ,it is recieving two + and - at supply end.I (1)thought of a crank sensor.(but why is there no resonse from PCM?)(2) cannot find crank sensor?
Oct 4, 2007 at 9:16 PM
