I have a 92 Transport with a 3800 , mileage is uknown do to it is not the original motor. I got it cheap because the guy thought the head gaskets were bad, well after some testing and a few beers I discovered it was the infamous intake gasket leakiing. So I changed the intake gasket, started right up and no over heating, but the engine light was on when I got it and I didn't check the codes before I did the intake. So I pulled the codes and repaired the problems. The magnet fell out of the cam sprocket, so I put a new cam sensor, magnet, timing chain, oil pump. Great thought I was in the clear, but now I get a code 56 qdm B (Quad Driver Module) and the engine starts out fine but then stalls when reving or driving. Changed the coil packs, and computer, no change. Plus the transmission makes a funny sound that I thought was the engine misfiring. Hoping for a sticky solenoid or bad wire on that one. Any help would be appreciated.
Sep 2, 2007 at 8:29 PM
