1997 Pontiac Transport fuel problem
1997 PONTIAC TRANSPORT
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRESUE04
When starting the van for the first time in the morning it starts perfect. But the next time(and every time after) it just keeps turning over until you push on the accelerator,then it will start, but it smells like it floods. Once started it runs perfectly. It doesn't cut out or miss or anything. We replaced the coolant temp. sensor, but that didn't help. Thank you for any help you can give us.
Feb 5, 2009 at 9:38 PM
When was the last tune-up? if recently -Do you hear the fuel pump when key at run? if so check the fuel pressure if its within specs. and also check for injection duration.
Feb 5, 2009 at 9:59 PM
