my transport just recently sounded like it had a bad knock only at idle but would disappear when rpms increased so when pressure was taken off belt tensioner it would quit so I figured water pump,belt tensioner,idler pulley so I replaced them but when I started it up the belt tensioner was snaping bad ....at closer inspection I saw harmonic balancer spin with something on outside so I shut it down got down and looked at the front the rubber part looked like it had been hacked clear threw with a hatchet or something so my thinking broken slot key or broken insde counter balance.... took it off key still ok only saw one counterbalance I think there should be two if one snaped off it would have bounced inside possibly causing it to rip the rubber membrane to tear would that cause the tensioner to snap making a knock?
Dec 12, 2008 at 5:57 PM
